New SS Prop,Help 1995 40 hp Mercury
Starcraftguy1
I have a 1995 Bass Tracker Pro Deep Vee 17,I want to get a new stainless steel prop.It has a Mercury 40 hp, it runs great now but would like a little bit more if possible.The boat runs 28 mph at 5500 rpm's now.Will a ss prop do anything to get a little more.Just asking before I go and spend any money for nothing.Thanks
steelespike
Re: New SS Prop,Help 1995 40 hp Mercury
Thats a pretty good performance for that setup.A 40 probably does something like 35 or 36 on a light fast boat.
Check out the Hustler turning point prop.Aluminum prop with close to SS performance.Usually these type props deliver overall performance improvement.I'd stick with a 17.
If your motor doesn't ventilate(cavitation) then you could probably raise it a little.Starting with the antvent plate(just above the prop) even with the bottom of the boat raise the motor with one 1/4" stick at a time to a point just before venting becomes a problem be sure it has a good grip and pumps water.One inch could gain a couple of mph.The Hustler will allow even more height.
Starcraftguy1
Thanks for the info.I had just had the carbs and fuel pump rebuilt,It's a wonder what $373.00 will do for a wonderfull time every weekend.
