New Starter won't turn engine...???
adam072101
78 OMC 305 with bad starter... replaced with new starter. The starter now turns over, but doesn't turn engine...
any thoughts?
Bifflefan
Re: New Starter won't turn engine...???
any thoughts?
Sounds like you have the wrong new starter.
Bt Doctur
wrong starter
flywheel teeth missing
hydro-locked motor damage
JustJason
is the starter actually kicking out and trying to turn the motor?
Check all your battery connections for rotted cables/cable ends
bruceb58
When was the last time your old starter turned the motor?
