NEW STATOR??? 225 ficht won't start
Starts fine runs fine but stopping after long runs will not start again. Next day fires back up and same thing happens.. batterys are fine???
boobie
Re: NEW STATOR??? 225 ficht won't start
Take it to a dlr and have him put his laptop on it and see what codes have came up before you just start replacing parts.
Yea they did and said its the stator. Jus wanted to know if that seems right because it does start 60% of the time?
Haffiman
'They said' is not directly acceptable. Got a read/print-out from the EMM?
Starting 60% is not either acceptable after a repair - it should start 100%!!
I'm not quite sure they got it right.
No they have not done the work yet. Waiting on the part. Jus wanna know if that is a likely symptom of a bad stator
Haffiman
To have an opinion on that, I would need the readings from the EMM, stored soft codes, ev. hard-codes as well as voltage readings when cranking and engine not starting. Add to it all, perhaps the most important: the cranking RPM??????????????????????????????
