new to 4 stroke
rampage12
well im new to the 4 stroke world, always had 2 stroke and loved them but came across a 08 25 nissan 4 stroke injected. i was wonderin how good of a motor this is and king of speed i could possibly expect on a 15x46 weldbilt boat... 100ga.. and r they well built and reliable?
pvanv
Re: new to 4 stroke
We've done a bunch of 25/30 EFI motors. All reliable, all smooth. All with brisk (no bog) acceleration. The usual maintenance rules apply... regular oil and LU lube changes, and draining of the fuel system's vapor separator if storing for a few months. If you will be storing the motor in freezing conditions, verify that the exhaust housing has a 5mm drain hole near (slightly above) the oil drain plug. If not, have your dealer add that.
hipster dufus
Re: new to 4 stroke
i have a new 1648 mv weldbilt, 100 ga. 30 hp efi tohatsu. 16 hrs. tpped out at 30.1 mph, gps. 2 people and gear will run 27 mph wot. +/- 1 mph. cruise all day @ 4400 rpm @21-22 mph. uses very little gas. actually went and bought the 3 gal tank. the 6 gal took up too much room in the boat. if i think i might need more gas i will take a 1 gal can with me. no choke and u can start it without a battery
rampage12
Re: new to 4 stroke
ok.. so where should this drain hole be.. wouldnt have a pic would u.. and what is hole for.. .. and hipster.. how du like your motor and boat? ive been hearin alot of bad things about weldbilt only reason i havent ordered yet.. i may go with 15x48 because they dont do 46
pvanv
Re: new to 4 stroke
Your dealer will have a tech bulletin on the drain hole. Allows complete draining of water from the exhaust housing "leg". Applies to long shaft motors of a specific serial number range. If you have a short shaft, not necessary.
hipster dufus
Re: new to 4 stroke
i ordered my weldbilt from backwoods landing in al. love it so far. i carpeted it. u can see some pics at their facebook page. very heavy gage 100. in hindsight i think i would have been ok with a 80 gage. the trailer is way heavier duty then my last one and comes with led lites and ez lube hubs. mine is painted. the engine is my 2nd tohatsu. i am in love with it so far. i am real anal about maintenance. i really watch my gas and do not ever let it get old.u will hear a lot of good things about backwoods landing, i drove 250 miles one way to pick it up. let us know how it goes.
rampage12
Re: new to 4 stroke
Yeah it's short.. just ordered my 15*48 100gu tunnel . Can't wait.
rampage12
Re: new to 4 stroke
what pitch prop yall think i should run? got my hardline tach today gonna get it on and see where im runnin.. be bout 4 weeks till i get my tunnel from weldbilt runnin a 15x46 express right now
rampage12
Re: new to 4 stroke
what should the motor be idle at on rpm.. mine reading bout 600 rpm.. and how do i do the vapor seperator on the fuel system.. thanx guys
rampage12
Re: new to 4 stroke
what setting should my hardline be set to?.. gettin a weird readin at wot
pvanv
Re: new to 4 stroke
Your tach is reading incorrectly. Idle is 850, +/- 30.
If you need to drain the vapor separator for storage, open the brass drain plug at the bottom of the bowl. The exact location will be clear once you review the Factory service manual (available from any dealer, including me).
pvanv
Re: new to 4 stroke
What setting should hardline be on
Never used one. We typically use the Factory tachometers, which are alternator-operated. What is it set to now? What options do you have? I would call hardline for ideas. Many inductive tachs will have problems with the very-high energy ignition systems on modern CD-ignition outboards. Sometimes that can be fixed through careful routing of the sensor wire.
rampage12
Re: new to 4 stroke
setting 1.. 1p1r= 1 pulse per 1 rev,, setting 2.. 1p2r=1 pulse per 2 rev,, setting 3.. 2p1r= 2 pulse per 1 rev.. says its for 4 stroke efi motors
rampage12
Re: new to 4 stroke
i do know mine is 3 cylinder .. did not realize it was only for 2 cylinder motors though.. that sux.. guess it wont work then
rampage12
Re: new to 4 stroke
not sure y number of cylinders matter.. should spark same on revolutions no matter of cylinders
hipster dufus
Re: new to 4 stroke
i am running a tiny tach on my engine it is set for 360. it has a resetable hr meter and a total hours. easy to install. i was just out for the first time with 3 guys and hit 25 mph still.
