Alright, so I just purchased a 1989 Larson DC190 with the 3.0L Mercruiser. It was winterized and hasn't run since (last year).
I have automotive repair skills, but have never worked on a boat... Anyhow, I replaced the rotor, cap, wires and plugs, changed the oil and filter on the engine and topped off the gas tank with high octane fuel. I checked the outdrives oil level and it was good. I threw on the ears and got it going. I brought it to the lake and it ran okay, however, I think I need to replace the gimbal bearing. It has a loud humming noise that changes as I trim up and down and doesn't really change much as I turn. I have a SS prop on it and the speedo isn't working, which I read could be an easy fix by blowing the line for clogs... I need to adjust the idle. Are there any fine tuning methods I can find online about the carb?
Are there any tutorials on changing out the gimbal bearing?
I've read a few other posts about replacing one, but are there any other things I should look into while I've got the drive off?
Thanks in advance!
What are bellows? (like I said, I'm new to the boat ownership)
Thanks in advance!
