New to boating.. help
Swwrenn73
Hello everyone. I am new to boating and would welcome all the help, advise and tips you can give me. I have a 1977 AMC Slickcraft 19' with an inboard 351. Getting ready to take it out for the first time. Don't want to make any big mistakes from launching back to loading.
Silvertip
I trust you've taken a boater safety course? Failing that, have you at least read the "Rules of Road" (for the water of course). Are you familiar with all of the controls on the boat. If you have not practiced backing, by all means go to an empty parking lot and practice backing. Some folks have no patience when having to wait for a novice at a busy ramp. Others may offer help. But it is best to practice and then go to water on a weekday when there is less traffic and lines at the ramp are not as long. Take an experienced boater with you to help and guide you. Experience is the best teacher but there is a lot you can learn before you leave the yard for the water. Leave the kids at home for the first few trips. You have your hands full learning how to operate the boat. You don't need the distraction of the family.
Sprig
Your question is too broad. I have no idea where to start. Do you want to know about launching, retrieving the boat, towing the boat, operating the boat, equipment, safety, rules of the water, boat handling and on and on. A large volume book could be written trying to answer everything. Narrow your question down and be more specific. As you are provided with information you can always ask more questions. What Silvertip said is spot on.
JimS123
I've seen the likes of you many times in my 65 year boating career. Many were accidents waiting to happen. As others have said, you need edumacation. Regardless, book learning is only a small part of it. Find a friend that is experienced and have him go with you several times.
roscoe
Safety first, fun second.
Does everything work on the boat?
Were you given a sea trial by the seller?
Blower?
Bilge pump?
Plug?
Is it sea worthy?
Bellows?
transom?
We need more info.
Perhaps a link to the ad from the seller?
TimB19
Safety/Legal: Make sure you have up-to-date requirements for life preservers(1 for each occupant and 1 Type IV throwable), Flares, Air Horn, Fire Extinguisher, and oars incase you break down and are getting pushed against land. Keep Registration in boat, ID on you, and have current registration + boat numbers properly on boat.
Few other things you may/may not have done as well: Make sure plug is in boat when launching, Always run the blower before starting due to it being an I/O, make sure your engine is trimmed up when launching if its shallow water.
Swwrenn73
I am a very experienced driver with a trailer. I have my CDL. I have everything on the boat I need. I have owned boats before but never an inboard. Where I live I don't know many people and those I do don't know about boats. Yes I have a bilge pump, plug is in, those things I know about. I don't know what trim does, I know how to operate the throttle controls and the safety of boating.
PITBoat
So you're new to I/Os then, not boating...
Trim has to do with the operating range of the drive while underway, and Tilt, you're starting to get into the trailering only range, if I understand it right.
Don't start it tilted Up all the way (look at the angle, imagine the u-joints inside, and you'll understand why). And as has been said, you probably don't want it trimmed Down all the way near the ramp or other shallow areas.
Make pre launch and pre start checklists that cover the critical stuff. Might not hurt to have one for loaded but still in the lake, and pre- back on the road too.
For the out on the lake part, that depends on your boat. Is it gonna leave you out there, etc., or not...
wahlejim
Master Chief Petty Officer
Just to echo what some others have said, safety first. I always go on a weekday in a new to me boat, everything is less stressful from launching to retrieval when you are not rushed. Even experienced boaters get flustered and make mistakes in pressure situations. Make sure the plug is in!
With that being said, chose a smaller lake that you know the boat can handle. Look at a map of the lake with depth indicators, easily available online now. As you are out there, learn the capabilities of the boat and any boat specific nuances that you learn from experience. I would personally go solo or with a mechanically inclined buddy the first time out to minimize distractions.
Silvertip
If you've not operated an I/O powered boat there are some things that you absolutely need to know. If this is a trailer boat, before you leave your yard or storage area, inspect the exterior of boat, especially the outdrive. It should be obvious what to look for but a puddle of oil beneath the drive would be a sign of an issue. Raise the engine cover and check oil, power steering, belts, hoses, plug wires etc. Fix things now so you don't need to call for a tow off the water. Check trailer tire pressure and that the boat is secured on the trailer. That includes bow and stern tie downs. At the ramp, before you turn the key: 1) Know what the blowers are for. If you don't know, they ventilate the engine bay ridding it of gas fumes that can go "kaboom".. 2) Know when to operate them, Operate them for several minutes before you turn the key. 3) Ensure the blowers actually work. I've just touched a few major topics. You will need to experiment with "trim" but your behind is the best gauge for the proper setting. Trim up a little to get on plane. When on plane begin tweaking the trim up and down to find the best setting. Trim is about right when you hear the rush of water at the side of the boat become much quieter. The boat will also tend to flatten out and ride smoothly. Always trim up when approaching shore to avoid hitting the bottom. As was pointed out, trim up too far you being binding the U-joints and breaking things. As with any vehicle, use common sense.
H20Rat
Plug should be out, not in. :D (at least on the trailer, it is actually illegal to go down the road with the plug in the boat in many states)
What type of boats did you own previously? Post some pics of the boat! Not many boats left of that age, so always kind of cool to see one.
kpg7121
If you're trailering your boat don't leave home without a spare. I joined BoatUS for their towing coverage which has a service which will have your boat/trailer towed if something happens on the road & you can't fix it. It came in handy for me once when a wheel bearing grenaded 30 miles from home. Something to think about.
Old Ironmaker
You must have had very old I/O's if you don't know what trimming is. Each and every boat will trim differently, even the same boat with different water conditions and what load is on it as in how many people and stuff. Play with the trim, when you hear that boat getting bow down, the speed increase with out throttle input as well as a reduction of RPM without throttle input. You will get the hang of it. Good luck, stay safe and have some fun out there. I've always had a problem with people saying "I know, I know." Then find out they don't know a thing. I wasn't the most liked trainer at the plant. Especially when I came up with written and oral tests to qualify workers, including Supervisors. When we made a mistake yes damage to equipment could be done but those same mistakes could lead to a personal injury up to and including death. The same goes for boating. You are responsible for the lives of everyone in and even those outside your boat. They don't have turn signals or brakes.
Old Ironmaker
That's not what you said in your original post. New to boating or not? Each and everyone that responded assumed you were not experienced because you said you were new to boating. Which is it? I hope you aren't a "I know, I know" person..
cptbill
Might help to know where your planning on launching your boat, I don't really know anywhere that I/os haven't been
roffey
From reading back through the post I see that you have experience with boats, just not I/Os. Outboard and inboard / outboard "operate" the same. The big difference is starting them, you need to open the dog house or run the blower for several minutes to vent the gas fumes. Other differences are when winterizing the boat and things like cheeking oil and hydraulic levels, things you likely will do even with out been told, lol. As far as trim goes you just experiment. You will feel the boat rise out of the water and RPM go up along with your speed. My boat goes a good 10 mph faster when trimmed up. You won't hurt the boat by not trimming it, just use more fuel and get a little harder ride.
My advice is don't go to far from the dock if you don't have a boater buddy and bring a cell phone, other than that its trial by fire, lol.
roffey
sorry, just reread your first post and your post, you said you have a inboard. Inboard motors do not have tilt adjustment, maybe trim tabs? like in my first post, don't go to far from the dock if you don't have a boater buddy and bring a cell phone.
