Hey guys,
So, to start I need to tell you guys that I have just bought my first boat. its a 1990 Arriva speed boat with a 150 hp Force outboard motor. I bought it from a guy on my fire dept. who assured me that when the boat was last used (2 year ago) It ran perfectly was then winterized. He didn't want it anymore, so he gave me a great deal. My dad has been helping me a little bit. I am sorry for my terminology as I am still learning. We replaced the lower end gear lube. It was black but there was water in it. I have been doing as much research as I can trying to filter out what I need. I put some fresh fuel in the tank after draining out the old little bit of fuel and there was almost nothing in the tank, hooked my hose to the motor to see if it would turn over. The motor backfired once during the initial first 2 cranks then it started right up ran for a few then died. I am happy that it started. There was no water coming out from the top 2 holes. I think they are called the pisser? I also didn't see any water coming out of the exhaust. Now where I live the water pressure sucks. so some advice please. Should I attempt to replace the water pump and reseal kit or test it out first. I am pretty mechanical. I needed a project because my wife made me sell my car I worked on a lot. It was fast enough to mandate a roll cage at the drag stip. Anyway what should I do before I take it onto the lake?
The motor is the original motor that came with the boat. I could not find any info plates. I will attach a few pictures of the motor tomorrow when I can. Its a 5 cyl. 150 hp Force. It says US Marine on the plate. If you could tell me more about it that would be great.
Please help me if you can.
Thanks,
Kris
Thanks,
Kris
