Terry Stephenson
- May 12, 2005
- 8
I recently purchased a 1983 Renker I/O with a 2.5L GM Motor, that had been under a canopy for about 4 years. After I attempted to put oil in the foot I noticed 2 days later that there was a leak. Upon further inspection I discovered behind the prop, a open cavity, through which I could see the foot oil. I noticed there are two tapped holes with no bolts, and what appears to be a worn gasket on it. It looks like some sort of gasketed plate goes there, but it was not with the boat. I have no idea what I am doing. Could I be right about the plate needing to be there? It is located directly behind the prop and spacer. If there is a plate, what would it be called so I can locate a replacement?
