jimmwaller
- Nov 30, 2013
- 274
Hello,
I recently bought my first boat (1970 starcraft islander, i believe the motor is a pre-alpha mercruiser 165) and I have two questions about I/O engines. (okay, not super recently, but I've been fixing other stuff and haven't had it in the water yet :/) I've really only had outboards up until now and could use a little help!
Question one: I have two marine batteries on board. So far, even though I only start it up once every few weeks, they seems fine, but is there a recommended practice on how to keep the batteries in good condition? I was thinking like a solar trickle charger or something, but I don't know if there's one model that people love, or if there are certain features to avoid, etc. Or is it fine to just let them sit?
Question two: This is an older motor, and I'm going to be using it in a saltwater bay. I thought about putting closed cooling on it, but I got talked out of doing that because everyone said it would just clog and it wasn't really worth it unless I was going to completely disassemble and de-scale/de-rust the whole engine beforehand. So I'm just going to use it as-is, and flush it out every time.
Just to make sure I have the flushing process right: I pull it out of the salt water, and just run freshwater through it, just like an outboard? I was thinking, what if I filled a tub or something with fresh water, and ran the engine in the tub, and put in like a salt removing chemical every time? Would that help, or is that overkill? I'd like to do whatever I can to help keep this motor going for a long time to come, and will happily take any suggestions
Any thoughts on either would be appreciated,
thanks!
thanks!
