Paul Yoder
- Nov 15, 2011
- 5
I recently purchased a 1995 Regal 202SC. It's powered by a 4.3L LX Mercruiser. S/N OF361057. I received minimal maintenance records with boat. Boat and engine are in good condition.
Some questions I have are:
What is the hp? I can't find it listed anywhere.
What maintenance should I do prior to starting the boating season? Got slip, I hope to put in here in spring and not have to pull out till fall.
What oil should I run? Type and brand. Only use in fresh water here in PA.
How often between plug and wire changes? Calendar and hours
Where is the best place to get Mercruiser parts on line?
I was planning on the following:
Oil change - engine and lower unit
Impeller change
Thermostat change
Belt change - all belts
Cap and rotor
Please let me know your thoughts.
Thank you,
Paul
Impeller change
Thermostat change
Cap and rotor
Thank you,
Paul
