new to me motor
poor man
hi guys, just picked up a 1973 evinrude 65 hp runs good (in tank of water) looks real good, start on the first crank, BUT i cant see any "tell tale" or water coming out any place to tell me the water pump is working..... HOW do i tell??? also the end of the mod# ends in R what is the R for? thanks again....
Re: new to me motor
Facts for you.-----If you do not know the condition of the impeller then install a new one.-------Water will spit out of the 2 exhaust relief holes at idle.-----------Test the overheat horn in the control box.
poor man
Re: new to me motor
ok, i have no water spitting out of the 2 holes BUT it ran for about 15 min and i could still put my hand on the top of the motor/head and it wasnt extremely hot at all .... i was going to replace the impeller because i dont know how long its been in there, and how do i test the over heat horn??? thanks for the help///
emdsapmgr
Re: new to me motor
The common telltale did not make it's debut on the OMC outboards till the 78 model year. Your engine may only put out a light mist from the two exhaust relief holes after it warms up. Start your engine when cold. Hold the palm of your hand back by the two midsection exhaust relief holes. After about a minute, the thermostat will open. When it opens, water droplets will start to form on the palm of our hand when at idle. That's normal, and a good sign.
poor man
Re: new to me motor
thanks, i do get water "drops" on my hand when i hold it there for a bit, i think im going to put a telltale on it myself and a new impeller, thanks
Vintage Boat Guy
Re: new to me motor
I know with earlier 40hp models, the thermostat would only allow water through at a certain temperature. To make life easier to test your impeller, take out your thermostat and water should come out if the relief holes. Also it may be a good idea to replace the thermostat as well.
