New to pontoon - q's
7lazy77
I am considering upgrading to a used pontoon & had a few questions. I have never owned a pontoon & am looking for something to do some fishing & trolling out of, but also something that will give us more room & to accomidate friends too. What do I look for when looking at pontoons? Is there anything to be "aware" of.
I came across a 1985 Playcraft 21' for $3000. It has a 50hp Mercury outboard on it. Seats are in great shape & when not out on the lake, it has been stored indoors. Is this a good brand? What about the price?
lncoop
Re: New to pontoon - q's
As a brand, Playcraft is fine. In fact, it's part of a shrinking number of pontoon builders still in existence. That's no mean accomplishment in these times. However, when we're talking about 25+ year old pontoons the brand doesn't really matter that much. Price is significantly impacted by geography, but in my neck of the woods three grand would be at the top end of fair provided there was a trailer included and everything was ship shape and ready to splash.
The nice thing about used barges is the absence of any potential disasters lurking out of sight (with the exception of the power plant of course). Everything is out there for all to see. Look under the helm for potential wiring issues, turn the wheel back and forth to verify the steering mechanism (likely cable at that age) is in working order (not a huge deal if it's not, but definitely ammo for haggling). Jump up and down on the deck. Shake the railing in different places to check for looseness (some is to be expected; too much is annoying at best, safety issue at worst). Look under all the seats. Look underneath the deck for missing bolts, screws, or rivets. Look closely at all the weld joints to be sure nothing is compromised. Place your head within hearing range of the toons and shake the front of the barge vigorously to listen for sloshing, which of course indicates leakage. Leakage shouldn't necessarily be a deal breaker, but is definitely another significant haggling factor.
Jack up the trailer one side at a time and try to jiggle the wheels to check for play, then spin them to listen for bearing noise. Check the lights and the bunks. If it has brakes they're likely toast. If so, addressing that issue will be expensive. Again, not necessarily a deal breaker; just remember to factor it in. With that size motor the rig could well be under 3k pounds, which in most states is the magic number at which brakes become mandatory, so depending on your tow vehicle it may not even be an issue for you. The seller, however, does not need to know that.;)
Check the compression on the motor, then water test the rig.
You'll enjoy trolling and bait fishing from a pontoon boat. If you do a lot of bass fishing; flipping and pitching, etc., you'll find a barge isn't the best boat for that. It is possible, just not ideal. That's a good size for versatile use. You'll find that a 21 footer is small enough to tow while being large enough to facilitate relaxing. She'll probably top out around 15 mph with that fifty, but you probably already know that. If she checks out and you like 'er, get after it. Let us know.:cool:
7lazy77
Thanks for your help & input! Greatly appreciated!
JWhit
agree on all points, and my main suggestion would be to make sure the motor looks clean and runs well. from experience it's easier to cover some seats or add accessories than rebuild or replace a motor. As long as it's reliable, you'll enjoy. Along the same lines, for old toons the brand doesn't matter too much and i'd rather have a good motor brand than pontoon brand
7lazy77
Had a chance to look at the pontoon this weekend. The thing that concerned me was the toon were foam filled & had a few patches. With the research I have done on here, this is not a good thing & it is hard to tell how much (if any) water is in there. Is this a deal-breaker?
Bamaman1
+1 on the above points. I would be hesitant to buy a pontoon with patches.
You're becoming more knowledgable every day, and keep on looking.
rogerwa
They were not filled to begin with, at least not that I am aware of. I would keep looking. Also, get the biggest diameter toons you can get.
JWhit
some toons are foam-filled to start, so the patches would be my only concern there. like you said the foam makes it harder to identify a leak as the shake approach may not work as well
lncoop
Actually, it's likely they were. Playcraft and a few others built them that way then. If we're talking actual patches as opposed to a leak here and there with a weld on it keep looking. New metal patched in would likely mean the foam became waterlogged and had to be removed. Now, if what you actually mean is a welded up leak or two that's different. There is nothing inherently wrong with toons that have been spot welded as long as the job has been done right.
