New Tool
BoatBuoy
Got an air hammer/chisel today and the instructions say to put a few drops of Pneumatic Tool Oil in the air inlet before using. I'm all out of Pneumatic Tool Oil and wonder what oil might be a reasonable substitute. Any ideas?
Kenneth Brown
Re: New Tool
I use a 3in1 oil. Not saying its correct but I have never had a air tool fail in about 10 years.
ZmOz
Re: New Tool
Most anything oily will work. I usually use deep creep or transmission fluid.
puddle jumper
Re: New Tool
ATF or 10w motor oil works just fine but why not just go down and get some its cheep.
BoatBuoy
Re: New Tool
"...but why not just go down and get some its cheep."
Right now I have 30W oil, 5W30 oil, 10W40 oil, TC-W3 oil, 2-cycle oil, cutting oil, jack oil, 3-in-1 oil, compressor oil, differential lube, gun oil, reel oil, ATF, brake fluid, powersteering fluid, outboard gearcase oil, etc. I thought, surely I have something that might work without adding further to the inventory.
Re: New Tool
with the Exception of the Cutting Oil,...Differential Lube,...Brake Fluid,+ Outboard Grease,...
Any of the others will be Just Fine............
DHPMARINE
Re: New Tool
wOW hate to see some one so under oiled !
DHP
I've ben using 50:1 oil in air tools for years.My preference is Marvel Mystery Oil,but I don't use these tools a whole lot.so I use what I got.
rickdb1boat
Re: New Tool
I give them a shot of fogging oil. Seems to work pretty good for that and other long term oiling needs...
moeMC
Re: New Tool
fogging oil is cool ,but add a little ATF for it's detergents keep tool inards clean
rwise
Re: New Tool
lack of lubrication sucks
when I worked on air tools wd40 was the oil of choise.
