Wave34
- Oct 17, 2017
- 341
I bought a new trailer last fall just before winterizing my boat, so I didn't have time to test it, I only pulled the boat out of the water once.
My first question is about the height of the boat on the trailer.
There is 4'' between the hull and the top of the fender. My friend who owns the same boat but different trailer, has 2-1/2'' over the fenders. A iBoats user reports to have 1-1/4''
My friend says that I should lower my fenders and cut my bunks to lower the boat, so I don't have to backup too much in water. BUT, a work colleague who also owns a similar boat, tells me to be careful with that and I should stay like that because the boat may touch the cross members.
My friend's trailer also has drop axles with the springs under them. On mine, I have the same drop axles, but the springs are over them.
Is my boat sitting too high?
Will lowering it 2'' make a big difference in retrieving it at the ramp?
(pictures at the end of the post)
My second question is about the length of my bunks.
All the trailers I see have a short length of outside bunks at the rear, and a short length of internal bunks at the front.
On my trailer, the four bunks are full length.
Is that better because it supports the boat on a longer span or it create a problem with friction while loading?
