New Trailer
Thomv
After giving it a lot of thought over the last 6 months I have decided to go with a new trailer for my 29 foot Powerquest. I was originally going to upgrade my 7,000 trailer by going with 5.200 pound axles, new 12,500 pound actualor and 16 inch tires. It turned out because of a trade in of my old trailer to a new 10,500 pound capacity trailer with 16 inch tires was only going to cost me an additional $800 more for the new trailer instead of going with the upgrade of the old trailer. When I got the new trailer I noticed the clearance between the inside top of the fender and the top of the 16 inch tires was only about 3/4 inch clearance. I brought my trailer and boat home and did not notice any rubbing. I don't feel comfortable with only 3/4 of an inch clearance so I need to raise the clearance by adjusting the venders. What is considered a good clearance between the tire and fender to prevent any rubbing. I was very surprised it did not rub with only 3/4 of an inch clearance on the ride home.
Re: New Trailer
Ayuh,.... It sounds like 3/4" is Plenty for yer application,....
You could experiment by puttin' an axle jack under 1 of the spring perches, 'n start jackin',....
If the other tire on that side comes off the ground, Before the tire yer jackin' hits the fender,...
It Can't hit the fender,...
Thomv
Re: New Trailer
I ended up bringing back the trailer to the manufacturer and they raised the fenders so now I have about 2 inches of clearance. Just wondering how much up and down movement I get with my torsion axles while traveling down the road?
