I sent a trigger in for warranty for my 50hp '90 force and I received it. Upon installing it, putting stator on, screwing in 4 stator bolts to a tad more than finger-tight, and then tightening flywheel down to spec (80ft/lbs). I cannot move the throttle all the way up or all the way down without help by hand moving the throttle tower at the motor. It was in fact 'stuck' in the neutral position.
So, I removed the flywheel, figuring maybe the flywheel was too tight causing friction, still same problem. So I tried loosening the 4 bolts securing the stator and this allowed the throttle to move up and down like it should. Apparently there is too much friction between the stator and this new trigger when the bolts are tightened down(barely tight). I had an old trigger and I put it on the same way and tightened the stator down all the way like I always had and it functioned normally. For some reason this trigger they sent me creates too much friction between it and the stator so it only can move properly if the stator bolts are loose. Has anyone encountered this 'defect' before? The trigger I originally sent back did not have this problem nor did the old one I tried. I am calling CDI tomorrow to get another replacement but this seems like a very uncanny problem I'm having.
