New Trim Cylinder Lines too short??? What did I do wrong?
kramerpage
Guys,
I just received trim hoses 32-9902 and 32-993 and they are 1/2 inch to short.
The casting numbers are 14034 and 14035
drive serial number # 0C735235
I went to Here's your drive and transom assembly parts, http://www.mercruiserparts.com/selec...29+1983%2D1990 that Fun Times gave me and it list two different hoses and says to see Drive Chart so I did and it states:
If trim cylinder casting numbers are 98703, 98704, 98703-1, or 98704-1, (Trim cyl. tube length15-9/16") order the following parts: (10-88432 Screw),(98704A3 Trim Cyl. Assm. STBD.), (98703A3 Trim Cyl. Assm. PORT), (32-99902 Hose-STDB.), (32-99903 Hose-Port), (Gimble Housing Assembly Complete 6-00019003)
If trim cylinder casting numbers are 14035-1 or 14034-1, (Trim cyl. tube length16-3/16") order the following parts: (10-90126 Screw),(14034A3 Trim Cyl. Assm. STBD.), (14035A3 Trim Cyl. Assm. PORT), and (32-99902-1 Hose-STDB.)
I guess this I why wish I had a local Marina to work with. Tanks for ay direction Guys.
achris
More fish than mountain goat
1/2" sounds very much like the same distance as the ports in the manifold for those hoses. The 2 hoses you bought (32-99902, 32-99903), they go in the AFT holes of the manifold.
Chris.........
kramerpage
Chris.........
Hi Chris. The solid tubing that runs down the ram that goes underneath the stainless plate with 2 screws in it is too short. I'll get a pic up thanks.
kramerpage
No Title
Here is a pic of the old screwed into ram and new that is too short next to it. Thank you
kramerpage
?Well i figured it out. Its 32-99902-1 and, 32-99903-1. The -1 after the part number gives you the slightly longer version of the hose. Geee Whizz
Fun Times
Hopefully the wrong ones are returnable? Plus I hope I didn't give you the wrong part numbers in your other topic...If so, sorry about that.
kramerpage
They are returnable. It's totally my mistake. I appreciate the help you have given me.
