New Updated Stats, so I probably need a new answer
GraAlaMat77
Last month I posted my boats stats trying to determine what prop to buy. Earlier this weak I blew a head gasket because I had a dimple on the head. The head was resurfaced and a new gasket was put in. The gasket was failing for a while obviously, and now the boats stats are different, so what prop? I have been told the Turbo Lightning 23,24,25 and the Tempest plus 23 and 25, but that was before the fix, so what do you think?
Old Stats
Boat: 1992 Ranger 391V Comanche
Motor: 1992 Yamaha Pro V 200
Prop: Predator - 4 Blades - 25 pitch
RPM @ WOT - 5300
Speed at WOT - 57.5
10" Jackplate
Propshaft is 3.5" below pad
Water guage psi - 15
New Stats
RPM @ WOT - 5600
Speed at WOT - 61.5
GraAlaMat77
Re: New Updated Stats, so I probably need a new answer
Also, what I want in terms of a prop is more top end. Thank you for your help.
walleyehed
I think I'd try a 25P Lightning....it's got a bit more lift than the Tempest, and I think you'll see the RPM come up with the speed.
Does the 391V have a step to the pad?
GraAlaMat77
im not quite sure what u mean, the pad is not even, there is a drop down sectio where the plug goes in and it comes back up to my livewell holes, its not all one linear surface, there are edges. With the turbo being a three bladed prop, should my rpms come up because im dropping the number of blades while keeping the same pitch?
walleyehed
Yes, your RPM should come up because we'd be running the same pitch, minus 1 blade, but more-so because of lifting capabilities, as in bow-lift.
The 391V has a pad and step by what you are explaining, and with a 10" plate, you are along ways back, in pretty stable water, so you should be able to get some good heigth even with a 3-bld.
You should be in good shape water pressure-wise, but I'd keep an eye on it with a lightning if running as high as it's capable of.
GraAlaMat77
Mark over at bassboatcentral said i need to be shooting for 5800-6000 rpms. Can i turn the 25p lightning that fast?
