New used trailer and fitment with my boat
beemnmatt
Looking for a little insight, new used trailer, aluminum, not sure if the weight distribution and bunk position is adequate
I am a little worried the boat is pushing the bunks outward, Just put it on today, I am ready to modify if need be....
thanks in advance!
beemnmatt
Re: New used trailier and fitment with my boat
Any Thoughts?
sphelps
I am in no way a trailer guru but just looking at it it seems that bunks that are there are more suited for a keel roller set up . The rollers would hold a little more of the weight . Maybe you should go for more of a bunk set up with the bunks laying flat and brackets angled inward.
Just an uneducated assumption ..
crabby captain john
It looks like - pictures never tell the whole story - the hull is not sitting ON the bunks but between them.
beemnmatt
It is definitely sitting on the bunks, the boat doesnt touch anything else until the the first support area in the front. The bunks are bolted to the frame and the wheel wells are bolted to the bunks. So there really aren't any adjustments I can do other than a complete redesign. I'm wondering if I can just leave it or should I redesign the whole thing......:confused:
WIMUSKY
I wouldn't use the trailer as is for any length of time. The hull is mainly being supported by the edge of the bunks. I would think over time you could damage the hull. There needs to be more surface area supporting the hull. You would need to modify the trailer to look something like the attachment if you want to stay with a bunk style.....JMO
Alwhite00
Master Chief Petty Officer
I would scribe the angle of the bunks to match the hull with the carpet off and grind, chainsaw or whatever, re carpet and be done with it.
LK
LippCJ7
No Crabby is correct, you are too but think about what he is trying to say your boat is setting on the bunk but in reality the load is probably equally pushing your bunks out and that isn't good.
I would add another bunk running just outside the strake, mounted horizontally this will make loading your boat much easier and take the weight off the outer bunk and making them somewhat redundant but make no mistake I would add the new bunks becoming the primary load carriers of the trailer.
Another thought is if you can turn the existing bunks 45 degrees it would help exponentially, wood doesn't like lateral pressure and turning your bunks into the hull would do wonders but I am not sure you can do this, the reason why I bring this up is I am not sure that your trailer can withstand the load of your boat being on the cross members, it appears as though your trailer was designed for the load of the trailer to be placed on the two mains of the trailer instead of the cross members so adding another bunk mounted to the cross members may not be a good idea afterall.
beemnmatt
LK
Something like this?
Alwhite00
Yes, I don't think your boat is heavy enough to warrant re-designing the bunk system, It looks like it fits pretty good other than it is sitting on the corners of the bunks.
LK
