dOb
- Jun 14, 2010
- 244
I?ve spent the last year or so on the resto forum rebuilding this old boat. Now I can start to work on the motor. It?s a 1974 Mercury 500 50hp. It will start on the muffs, but it isn?t very steady and it always had a really strong gas smell. The other day I discovered that gas was pouring from the lower carburetor when I would squeeze the bulb. I read up here, and decided that I should remove the carbs, clean them, replace gaskets and parts, and see if that solved the problem.
I know a little about car motors, and even less about boat motors. But I thought I'd give it a try. So the carbs are off and I have a gallon of carb soaking stuff ready to go. Then I start reading more, and keep coming across people saying that soaking is bad. Now I know from the resto forum that there are different opinions on every subject. But I started getting nervous. I finally decided that with the age of the motor, and not knowing the previous maintenance, I?ll go ahead with the soak.
Now, the question is, how far do I break the carburetors down? Do I just remove all of the plastic pieces and take apart where there are gaskets? I have no experience with rebuilding carbs, but I plan to document everything when I take them apart. Anything else to watch out for? And is it possible to soak for too long?
Sorry for the string of questions. Here are a couple of pics to give you an idea of what I?m working with.
Thanks.
Thanks.
