Newb Idiot question
Myjohnsonsbroke
hey guys first post here, I've got a 94 sprint with a johnson outboard. I'm trying to take off the lower unit. Ive taken out the 5 bolts but its got some resistance still. Am I supposed to take out any of the screws as well? I know I should not be jacking with stuff I don't know about but I'm going to anyway. I'm just trying to check the water pump as I was told it should be changed every couple of years. Any help on this? Also, what else should I do to the boat to make sure its lake ready as I'm not sure about the maintnance history. Thanks!
Dhadley
Re: Newb Idiot question
We'll assume the motor is about the same age as the boat. There are the 4 bolts on the side, the large center bolt and one under the trim tab. You'll also have to disconnect the shift.
tx1961whaler
What kind of Johnson motor? There are hundreds.....
Please post the model number....
and welcome to iBoats!
Myjohnsonsbroke
model no: J48eslerd
I have not disconnected any shift rod or anything other than taken out 5 bolts? how which screw or bolt disconnects the shift rod? and thanks for the welcome!
tx1961whaler
1994 48 HP then.
I think the shift rod is disconnected under the bottom carb.
wilde1j
You might try to get a manual or there will be more "Newb Idiot question ...s"
