Hi Everyone,
After lurking for a bit I thought I'd jump in and pick some brains;
Just a little background first - I'm fairly mechanically inclined with cars, motorcycles, etc but boats are new to me and I just purchased my first one and am trying to get her ready for the water..
It's a 1990 Sea Ray 160 that I bought from a friend, with a Merc 3.0 and only 420 hours. The boat was rarely used obviously but spent a good part of the last couple years neglected and uncovered.
I'm trying to examine all the common problem areas and address any issues I find and so far have:
Replaced the battery and all battery cables
Replaced the starter with the newer style (old one was dead)
Purchased the full transom seal kit and am currently in the middle of replacing
After I changed the starter, it only took a couple turns to start her up with some new plugs and she purred beautifully. I ran it a couple times with a muff on for only about 5 mins or so each time. Oil pressure and water temp were fine.
The issue now:
Lastnight while pulling the shift cable I noticed that the water hose on the front of the engine had been disconnected by someone and was tucked in a way that I just didn't notice. So, obviously the temp only showed as being ok because I only ran it for 5 minutes at a time, my concern is that no water ever came through the hose at all.. So, my question is, considering the common problems, should I assume the impeller is bad, the water pump, or both?? I don't know if it matters much but upon removal of the outdrive, the u joint bellow was full of water.
Thanks in advance for any thoughts or suggestions!
