Newbee need advice!
sands
I'll pick up a 1996 Bayliner 22.5 carbin cruiser with 350/alfa1 tomorrow. This boat haven't been in water for 2 years (winterized 2 years ago) Please let me know what should I do to get ready. Thanks.
Nandy
Re: Newbee need advice!
I guess you mean get seaworthy ready... We need more information. Location, intended use, gear included, condition of the boat... so on... sorry, or crystal balls are not working tonight!!! ;)
mphy98
Oil and filter change, drain and replace fuel, replace lower unit lube, check all belts and hoses, check hose clamps, lube cables, do everything just like you would a car that has been sitting for 2 years and are about to go on a long trip.
ziggy
this might be a good place to start from the adults only sticky at the top of the i/o forum.. http://forums.iboats.com/showthread.php?t=192804
also from the sticky at the top of the i/o section ya'll find your service manuals for your rig too. get that. there will be a section in the s/m regarding preventative maint. to perform and at what intervals to do them too... check that out..
Ayuh,... Agreed....
Read the Winterization thread,+ the Summerization thread....
Then combine the points of Both threads to see where,+ what you should be checking/ changing....
