newbeeee
vithang
I am new at boating...
I was wander what is the trim and tilt. What is the different between them. and what do they do?
thanks
havasuboatman
Ensign
Re: newbeeee
Trim is what You use to adjust plane angle on the boat for best ride and performance.
tilt is what you use to bring the drive unit fuluu up for trailering
vithang
Re: newbeeee
so..
does it use the same motor to adjust the plane? is there a lock on both? and if so where? can you adjust the trim while running you boat? I have a 85 omc with 3.8liter outdrive.
havasuboatman
Ensign
Re: newbeeee
Yup, same motor does both. I don't believe your drive has a limit switch though. Most all the newer manufacturers do now.
WizeOne
Re: newbeeee
Is your '85 a Stringer drive? If so, it may or may not have had the trim option. The stringer used one motor for tilt and a seperate optional system for trim. The trim system would have raised and lowered (pivoted) the whole engine/intermediate/outdrive, from the front of the engine, as a single unit.
If yours is a Stringer and you do not have the optional trim system, DO NOT use your tilt function for trimming. NO, NO, NO!
havasuboatman
Ensign
Re: newbeeee
I'm sorry, I thought that OMC switched over to the Cobra unit in '85.
Listen to the Wiseone if you are running a stringer, for he turely is.
vithang
Re: newbeeee
Great thanks for all the info.
I have another question.... what purpose does the two tilt solenoids have? Can I by pass them from the switch straight to the motor?:confused:
Re: newbeeee
Nope,... The Switches will Never be able to handle the amperage that the motor draws...
That's the job of the solenoids...
WizeOne
Re: newbeeee
You never did bother to answer whether you had a stringer drive or a cobra drive. How are we supposed to give you decent information?
vithang
Re: newbeeee
I am sorry that I avoid that question. I actually dont know if my is a stringer drive or a cobra drive and how can you tell the different.:confused:
KRH1326
Re: newbeeee
Can you post a pic?
Do you have a huge black rubber boot sealing off the transome about 1' x 1' from which the outdrive protrudes?
vithang
Re: newbeeee
I dont have a pic right now .... I will get some pic tomorrow... thanks
Bronc Rider
Re: newbeeee
The stringer and cobra drives are very different. Here is a pic of what they look like.
Here is a stringer:
The stringer has a boot at the transom where it meets the drive, cobra does not.
Here is a Cobra:
vithang
Re: newbeeee
great!
Thanks Bronc rider.
My is a stringer then. My must not have a trim then.
thanks everyone.:)
