speedyfreak24
- Jan 3, 2008
- 19
I cut out a few areas of rotten deck in my 1989 Maxum and am replacing with 1/2" exterior grade plywood, wetted out with epoxy. The rest of the deck is fairly solid, but the top layer (under the carpet I am going to reuse) of what looks like chop strand resin is heavily abrated and UV weathered to the point that the wood under it needs more protection. My question is:
Once the new plywood is epoxyed in, what oz. of fiberglass cloth should i cover it with? I then want to add one or two ? layers of cloth over the entire floor and wet out with epoxy before putting the carpet back down, to make a stronger more water tight deck. What oz. or how many layers of fiberglass cloth should I use? Thanks so much.
