Newbie- First Boat
Andy J
Hello Everyone,
We purchased a 1972 Winner Bimini a few weeks ago which is my first boat. I have been searching several weeks to figure out what I have and how to maintain it which most came from this forum.
Here is what I know about the boat-
- 1972 Winner Bimini Inboard
- Previous owner swapped the 2.5L engine for a 1987 OMC 3.0L GM 302AMFTC
- Sterndrive is a Mercruiser with a label HP 120/140 and the serial # is 3418026. From my research it's a MC-1???
There are 2 categories on the forum Mercury and OMC Outdrives, does this mean the Mercury Outdrives had a Ford engine only with the package and OMC was GM? I want to try and post my questions in the proper location.
Thanks,
alldodge
In you case being a mix, if its a engine question go OMC and if its the drive the Merc
Andy J
Appreciate the help...... So they are not normally mixed correct?
Andy J
Andy J
Marc,
I have worked on Automobiles for 35+ years and assumed the Ford and GM blocks had different bolt patterns that wouldn't allow parts to be exchangeable. Boating does seem to be different from what I have learned in the last 3 weeks. LOL
Marc,
the 3.0 is a GM industrial motor made in mexico used by everyone that used the 3.0...... OMC, Mercruiser, Volvo, etc. however only the block and heads are from GM the other content comes from the company that marinizes it.
so if your OMC motor was stripped down to the long block then built back up with all merc parts......its a merc.
if your OMC was not stripped down to the long block and retains much of its OMC specific stuff......its a frankenmotor.
alldodge
AD, if the OMC block had all the mercruiser stuff put on it then wouldn't it be the same as a mercruiser?
Agree, just going by what I'm reading, don't know the full story if there is on :noidea:
Until there is a problem asked, I'm in the doesn't matter opinion
Andy J
I didn't get much info when I bought the boat, owner had just put a rebuilt 3.0 engine in it. I think the Merc Sterndrive is original as the serial # matches the year of the boat..... Not 100% though.
Did I understand you correctly that all 3.0 L engines are from GM?
Yes, all 3.0 motors are GM industrial motors. Fork lift, trash pump, generators and marine
Andy J
I appreciate the education, makes sense now. I have learned much in the last few weeks but some things I can't find answers using a search bar. I hope to be a resource also one day once I learn and can pass it forward.
the thirst for knowledge is a start.
Marc,
Ayuh,.... The original 2.5l was also an ole Chevy motor,.....
The little Ford motor OMC used was the 2.3l,......
