Newbie here with a tilt and trim motor leaking fluid
Ellisv6
Hi everyone I just got a 84 Stryker bass boat with a 85 HP force motor the power tilt and trim pump motor is leaking fluid looks like its leaking between the motor and the valve body can anyone tell me where I can get the o rings for it I can't seem to find anywhere
Ellisv6
Hi jerryjerry05 thanks for the info I see it says it's a cylinder kit would it have the o ring that goes between the motor and the valve body it seem to be leaking there not the cylinder
jerryjerry05
There shouldn't be any oil coming from between the motor and reservoir??
Unless it's been filled wrong?
Over filling can push oil up into the electric motor??
They get filled when in the down position and use 30w oil.
If they get filled when up, then you drop the motor down, the excess oil gets pushed up into the motor.
Here's the part#
Ellisv6
Thanks for the part number actually I think it's coming out from between the reservoir and the valve body ,the part where the lines go in . Thanks
