Here's another question. :redface:I have an 88 20hp johnson that I noticed after a quick spin had a little bit of oil coming out of a small whole that is on the left side of the lower unit. It was just a bit. I ran the motor at home with water running through and no oil came out at all. Im not sure if this is normal or something is about to go. On the right side theres a screw with flat head top that I think is the spot to check the oil and maybe add. I would also like to know how to replace the fluid for the lower unit? THANKS
