huskerdaninva
- Jun 18, 2009
- 240
Hello and I appreciate any help I can get. I'm a newbie to this site and boating in general so please be gentle.
I purchased a 1969 Chrysler 14' Valiant w/ 1969 Chrysler 70 hp OB. She has been out of the water for at least 20 years and stored out of the elements. A TRUE barn find, as the boat looks to be completely original. I'll try and post pictures a bit later. Info follows:
Boat Hull # 640331583
Eng. Model # 7071 / Serial # 5145
Magna Power Ignition Power Pack Info:
Model # 6CB2012
Serial # 25719
Engine turns over freely, has very good compression, is getting fuel. etc. No spark. She is a 3 cylinder with Magna Power ignition & distributor and I suspect the power pack or black box is dead. The coil had a terminal broken off and a jerry rigged screw holding the wire, so I tried to use an automotive coil in an effort to get lucky,hoping for the best. With a marine battery hooked up to the cables and the key enaged in the switch, the starter turns over wonderfully, the ignition key activates the choke when pushed in, but no fire at all. I checked the neutral safety switch already hoping to get lucky...Any thoughts or advice? Do I have alternatives to purchasing a new power pack? Can another ignition system be swapped... say one without a distributor? Can I get a used box at a decent price somewhere? I just want to get this old girl fired up! Thanks again in advance...
"Husker" Dan
Model # 6CB2012
Serial # 25719
"Husker" Dan
