http://s211.photobucket.com/albums/bb270/PinkyRingz/Mirrocraft Project/
I am rebuilding/modifying a 16' mirrocraft aluminum. I have it almost gutted. I have yet to cut the front bow cover (not sure what it's called) off. I will remove the top of the bow shortly.
After looking at this boat i have some questions that hopefully someone here can help me with.
I would prefer to use a heavier gauge diamond plate aluminum for all the metalwork involved in stiffening of the boat. i want a flat floor with a small, raised casting deck in the front. A storage box/seat in the middle of the boat, and two storage box/seats at the rear of the boat in each rear corner.
Thats my dream. Now back to what i have.
i will build the boxes/seats out of plywood but from what i've been reading you guys coat them with some sort of epoxy or fibreglass resin. what exactly is it and it's purpose? To seal the wood completely? Also, after i make and seal all my wood pieces, can i screw them to the mounting tabs with any old screw or is one or another better?
Can i just drill holes and use rivets to join together two different thicknesses of aluminum? How heavy a guage of aluminum is "too heavy' for this boat or to work with?
Also the transom, how do i get the wood out of the transom, it's really really rotted and has some screwholes poked in it. i want to rebuild it proper and solid so it lasts. The tag on teh boat says it's rated for 75hp (although i'm only putting on a 25hp) i wish to rebuild the transom so that if i sell it or come across a bigger motor i can put it on.
Hints, ideas, recommendations, tips or tricks? i'm young, eager to learn and already got started. Just need some guidance then i'm off teh races! lol
