newbie restoration
greenwell001
hey guys...i am wanting to wet sand and buff some oxidation off the top of my boat....the question is...what are the pros and cons of removing the buttons off the hull for my custom cover to make buffing easier and make it look more uniform, the boat is a 96 and they are caked with (oxidation?) or something and i am worring about maybe stripping them out but i want to make the finish immaculate...also how are the hand rails on the bow generally attached, because i cant figure it out thanks
socom-medic
Re: newbie restoration
From my experience (somewhat limited but obtained at a cost of making some minor, yet time consuming and costly mistakes); the buttons or snaps are usually mounted to the hull using a course threaded screw. If you look in the center of the snap and see a Philips head slot pattern you should be able to remove / unscrew these by hand with a screw driver in order to remove them. Just be careful when screwing them back onto the hull so as you do not over-tighten them and strip out the hole.
As far as the railing mounts go, most boats are built in two parts; the top and the bottom and then joined together (the reason why there is usually a metal molding / bump cover around the whole outside of the boat). When they are building the top part of the boat they have full access to the bolts that mount the railing brackets. Once they fill the hull with floatation foam and join the two parts together, it is nearly impossible to gain access to both sides of the bolts. I made the mistake of unscrewing / removing the bolts from the mounting brackets and then had to use lag bolts and toggles to replace them. I wish I had just hand sanded around the mounting brackets and called it good enough.
Hopefully someone else out there will have a better solution then I was able to find when sanding and restoring my hull...
Good luck.
jonesg
nice sled, looks fast on the trailer.
If you can't get at the backside you might regret loosening anything.
greenwell001
hey guys thanks for the suggestions and compliments.....they are phillips screw heads but has anyone heard of them putting metal tabs behind the glass too keep them fron strippin...if i take em out hopefully i wont here a ting
Bob_VT
Nope they are just screwed in ....no tabs. When you re-install them you can put a drop of epoxy on the threads and they will stay tight and not strip out.
greenwell001
thanks bob.....i like that quote on the bottom of your post....must have been a smart man
Bob_VT
Kind of off topic..... you should google Randy Pausch and spend time and watch The Last Lecture The guy was smart
greenwell001
ok guys,
i have the buttons off and they have a lot of buildup on them....i am guessing they are stainless steel? what can i soak them in to remove the corrosion and make them look shiny again
thanks
