blurry
- Aug 21, 2012
- 24
Hi there. thanks for the great infer on this site!
I'm getting ready to service my outdrive myself for the first time. I've been wrenching for years, love working on stuff - never touched a boat though!
We have been noticing a grumbling and vibration which seems to be getting worse. with the outdrive trimmed down it is more noticeable them when raised slightly. right turns are more noticeable than left. The Gimbal bearing was replaced 100 hours or so ago.
problems started after we hit a submerged log (happened in the correct entry path between the buoys entering the channel). The prop was rebuilt and the drive has not felt the same since.
Plan to get all the parts I might need, if I don't need them I'll hold onto them for another day.
am I missing anything other than normal automotive tools? Any other gaskets or o-ring that should be replaced?
outdrive stand: http://stumpysfabworks.weebly.com/boat-outdrive-jack.html
alignment tool: http://www.amazon.com/Engine-Alignment-Tool-Mercruiser-Volvo/dp/B00E3V8P72
gimbal bearing puller: http://www.ebay.com/itm/GIMBAL-BEAR..._Accessories_Gear&hash=item4183cafd7e&vxp=mtr
two u-joints (i've read some can be replaced, some you have to get the yokes with it, napa purchase so returns are easy): http://www.napaonline.com/Catalog/C...-5-1306X-Spicer-Dana/_/R-TWR51306X_0427824061
u-joint bellow & clamp: (boats doesn't seem to have it) http://www.marinepartssource.com/newdetails.asp?pnumber=VP3841481&mfg=VOLVO&mfgno=3841481
Sierra Gimbal
exhaust bellow: Part # 3850426 : http://www.volvopentastore.com/Exhaust-Bellows-Kit-3850426-Volvo-Penta/dm/cart_id.023789403--session_id.467481691--store_id.366--view_id.289901
2' piece of 3" PVC pipe to drive the bearing in
new o-ring to go around the water hose - need part number
Marine Grease (have it from prop replacement)
thanks!
Sierra Gimbal
thanks!
