Newbie to forum and boating needs help, Please
timalew
Hi all
Name's Tim, hope you are all well.
Ok here goes....
Concerning a 1967?(not quite sure but pretty sure)
Starcraft 16' (looks a lot like the sunrise model of that year but only 16' not 20')
Engine: Chevy(Mercruiser or is that same thing in boats) I-4 151ci?? 120 HP I/O (runs great!)
Problems:
-Limitswitch to change gears shorting out coil?? Or just not working.(replace switch and where to find??)
-Not planing out has 19 pitch prop on which I'm guessing is too big(what's right size?)
-powertrim gets stuck when all the way up
-hydraulic rams leaking the tiniest bit of oil but still a concern
-where to find parts
-where to get engine specs
-boat is in pretty good shape overall needs some tlc
price was right at $800.00 (I hope anyway :)) with trailer and lots of extras
I appreciate any help
Thanks a bunch
Tim
Re: Newbie to forum and boating needs help, Please
You have a Mercruiser 120hp,.... with a Pre-Alpha, probably a Mod.0 outdrive....
GM(Chevy) built the long block,+ That's It......
If the motor is stalling when you shift,.... The Shift Interupt Switch is Working Perfectly,.......
What it's telling you is,... You need a New Lower Shift Cable........
You maybe Right,......
Or,......
The motor is Not putting out the 120hp it Should be..........
Greasing All the pivot points Usually cures That........
You can try to Rebuild them, or just replace'm...........
Here at iboats.com,.......Napa,..... Mercruiser,.....
Well,....... I don't have them,.. But somebody will be along that Does,......
In the mean time,...... Have a read Here,+ You'll atleast learn What things are called,+ how they Work......
