Newby Here, Looking for Post from J.Reeves
SawBum
Hello all, I read a post a few days ago from I believe Joe Reeves, It was detailed instructions on how to unhook and disable the VRO pump. I did this a long time ago per instructions from a great friend in the business but he has passed away now. I am haveing top end trouble, I may have found an air leak but I wanted to review how it was disconected. There is also a red knob below the pump on what looks like a fuel solenoid, it will only rotate 1/2 turn, i am curious as to what its function is, adjust oil??? Thanks in advance, I was in this site for hours before I decided to join......GREAT INFO!!!
tashasdaddy
Re: Newby Here, Looking for Post from J.Reeves
the red knob is the manual setting for the primer. the primer replaced the choke on these engine. it is activated by pushing in the key. if you leave the red knob in the manual setting it will flood the engine. left me see if i can find Joes post. couldn't find Joe's but there are 2 here, you could always send Joe a PM.
SawBum
Thanks, If you dont mind, looking at it from the top, which way is correct, clockwise or counter clockwise, and also, what is the schrader valve for?:confused:
Ron
tashasdaddy
it automatic, it is turned back in line with the body over the body of the primer. i know what it is but drawing a blank.
Joe Reeves
(Fuel Primer Solenoid Function)
(J. Reeves)
The RED lever...... The normal operating/running position is to have that red lever positioned over top of the solenoid and aimed at the other end of the solenoid, gently turned to its stop. This is the normal/automatic mode position. Pushing the key in opens the valve within the solenoid allowing fuel to pass thru it in order to prime and start the engine. Looking upon this solenoid as a electric choke results in a better understanding of it.
Having that red lever turned in the opposite direction, facing away from the solenoid, allows fuel to flow thru it to the crankcase area. One would only turn the red lever to this position in a case where the battery might go dead and the engine had to be started via the rope pull method. Look upon putting the red lever in this position as moving a choke lever on a choke equipped engine to the full closed position. Either one would supply fuel to the crankcase/engine for starting purposes BUT if left in that position while running would flood the engine.
The later model primer solenoids are equipped with a schrader valve, used for attaching a pressurized can of fogging oil etc, available at your local dealership with complete instructions.
Pumping the fuel primer bulb up hard fills the carburetor float chambers of course, but that process also applies fuel pressure to the primer solenoid.
The two small hoses leading from the primer solenoid branch off via tees to each fuel manifold section that would feed fuel to the individual cylinders.
Pushing the key in activates the primer solenoid to allow fuel to flow thru it to the intake manifold passageways. Cranking the engine over causes the fuel pump to engage which in turn sends fuel pulses to the primer solenoid via the 3/8" fuel hose.
Some engines incorporates the "Fast Start" feature which automatically advances the spark electronically so no advance of the throttle is required for starting.
Engines that do not have the "Fast Start" feature will be required to have the throttle advanced slightly.
Starting procedure: pump fuel bulb up hard, crank engine and push the key in at the same time. When the engine fires/starts, release the key so that it falls back to the run position.
Bottom line..... Look upon the primer solenoid as an electric choke.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
(VRO Pump Conversion To Straight Fuel Pump)
(J. Reeves)
You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup by doing the following:
1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.
2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.
3 - Mix the 50/1 oil in the proper amount with whatever quantity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.
That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
tashasdaddy
thanks, i saved for reference.
SawBum
(J. Reeves)
Mr. Reeves....Thank you. Your information seems invaluable here.
Ron
