ngk spark plugs
Johnson110
hello, first of all i want to say i thinf this board is great! i have a 1986 rebult 110 cross flow omc. now motor was rebuilt and got it back w ngk spark plugs so engine was timed with these plugs, question: should i keep ngks in it or switch over to champion thanks for advice guys
OBJ
Re: ngk spark plugs
Johnson....it's always good to run the recommended plug. Yours is a Chanpion QL77jC4 gapped at .030. But if you gap it at .040, it will show better idle and not affect top end.<br /><br />Good Boating and keep us posted. Thanks.<br /><br />PS...I got a 86' 90hp. Same thing 'cept fer carbs.
walleyehed
Re: ngk spark plugs
QL82C is a widely excepted plug now for that engine as well, by Champion, gapped as stated above.
seahorse5
Re: ngk spark plugs
Walleyehed is correct on the QL82C plug for your motor. They changed a lot of the plug numbers back in '95 or '96. You must be using a very old plug chart or the original book.
OBJ
Re: ngk spark plugs
Well guys...I looked at the latest parts locator disc and this is what I came up with.<br /><br />For 1986 Models....<br />Models 110MLCDC and 110TLCDC: QL77JC4 or QL16V. <br /><br />Models 110TLCDF: UL77V.<br /><br />Don't have the P&A book in front of me. I'll take a look today.
OBJ
Re: ngk spark plugs
P&A Book recommends either plug....QL77JC4 or the QL82C.
chris abela
Re: ngk spark plugs
I read somewhere that Johnson designed their engines with Champion in mind.
dritman
Re: ngk spark plugs
I was never happy with NGK in my dirtbikes, if they foul out the are done. If you leave them in have some spares on hand
Mark42
Re: ngk spark plugs
Hey Dritman,<br /><br />I double that! My Yamaha 2 cycle dirt bike ate NGK plugs. Sometimes they only lasted an afternoon of riding. The Champion plugs lasted for weeks on end. I think the NGK plugs would develop a hairline crack in the ceramic and short out. I was using the specified plug, and it looked OK, but it would lose the spark.<br /><br />Mark.
WillyBWright
Re: ngk spark plugs
NGK=NoGood Krap.<br /><br />Worked for just one dealer that used NGKs religiously. Seemed okay. Otherwise I prefer Champion if given the choice of either-or. Generally I like whatever brand is appropriate for the motor. NGKs on Japaneese OBs, Champions on American OBs, ACs on GMs, Autolites on Fords.<br /><br />And Splitfires on anything you want to go Poof.
