Nissan 3.5A water pump replacement
KenHup
is replacing the impeller as easy as removing the prop and replacing the impeller over the shaft
I have just bought the used motor and water stream is very low
anyone have a step by step so I don't miss anything
already purchased the impeller
Thanks
pvanv
Re: Nissan 3.5A water pump replacement
Yep. 2 bolts for the pump cover and you're in there.
pvanv
No gasket. You can use lock-tite or grease on the bolt threads if desired to reduce galvanic corrosion. No lubricant for the impeller -- it's water-lubricated.
Sea Rider
Those small 2,5 & 3.5 are prone to deliver poor peeing specially at idle, if so, remove engine lateral cowling, disconnect rubber hose from crankcase and run a medium wire, needle, plastic tie wrap, W40, Carb Clean spray red cannula back and forth small water outing several times to clear the slight salt, debris clog that might have formed. Will pee much better.
Happy Boating
KenHup
Thanks to all for replying
All suggestions were acted on
I replaced the impeller this weekend on board the boat
Really was a snap, I was not sure it could be that simple
I did run the wire through the water tube ans sprayed compressed air both ways with the impeller out
It flows great, I don't think it'e possible to get it any better
pvanv
You have a different motor, so you should start a new thread.
You did not mention model.
But.
You drop the LU (and disconnect the shifter), and install: WATER PUMP KIT : 4HP ~ 6HP
Water pump repair kit. Includes all parts needed to replace water pump.
Fits:
5B 2-stroke model
4/5/6hp 4-stroke models
Part #: 369873221M
List Price (MSRP): $48.92
Full info is in your Factory service manual.
