Nissan 40hp NS40C 361-A1 starting issues
Rob1976
Hey guys... I can pull start my engine after some starting fluid and 10 pulls. but it will not crank over with key. it seems like i ain't getting no fire or something is this possible or maybe a wire is not right. any suggestions ???
pvanv
Re: Nissan 40hp NS40C 361-A1 starting issues
Does the starter turn with the key?
TOHATSU GURU
Check compression, check for fire. If those are okay then you have a fuel system issue.
Rob1976
Yes, the starter turns with key. i have new battery and it seems like it isn't firing, i will check this next. thanks
Rob1976
OK guys i pulled the plugs out and checked for fire and NO FIRE on plugs now what ????
pvanv
Assuming you either used a plug tester or grounded the metal case of the plugs while testing, you don't have fire. Using your manual as a guide, isolate the problem to the exciter, pulser, cd, or ignition coil... or shorted stop switch.
TOHATSU GURU
You can either randomly replace each one of the ignition components or you can get a factory service manual and see which one is bad.
pvanv
Those compression numbers are very good. DX the ignition.
