maineiac5586
- Feb 14, 2009
- 771
Trying to remove lower unit. It uses 4 studs and nuts. I've been soaking the stud area and all around the parting line of the unit to exhaust housing for a week. Tried heating the area around the studs. It won't even drop enough to get a screwdriver between them. I tried hitting the lower unit along the raised section in the middle rear with a dead blow hammer. Should I try to get 2 nuts on the studs and try to back them out? Yes shift linkage has been disconnected. Not sure what else can be done here.
