nissan 90 hp no spark
mpfarm
installed a older Nissan motor and when I went to fire it up no spark. tested the stator only producing 26 volts . The rectifier is producing 6 volts. bot I need help
Sea Rider
Welcome to Iboats,
Don't know about that precise model but 26 Volts is quite low, on other HP models should be min 100 "DVA" volts measured with a DVA reading capacity multimeter...
Happy Boating
pvanv
What is your actual model? I don't believe that motor has a stator. Are you using a DVA-equipped meter? Did you test the CD?
