Nissan NS9.8 B 2 Stroke RPM Measurement
ChrisMA
Just picked up a 2002 Nissan NS9.8 B 2 Stroke outboard on a 10 foot rib inflatable. The combo runs great, but I am having trouble sorting out the idle RPM. The engine runs great, pushing the boat 16 MPH.
It is a 2 cylinder 2 stroke and I am trying to measure the RPM using a Oppama PET 1100R induction tachometer.
I * think* it is reading 2X what it should read. It idles very rough at an indicated 950 RPM, but increasing the idle to 1500RPM *seems* too fast. Does the engine fire both cylinders every time? I have not adjusted the mixture screw yet, maybe I have a dirty carb or a mixture screw that is off.
The engine will not die at idle and runs very strong throughout the RPM range so I am not sure what is going on.
I have not attached the tach at WOT yet to see what it reads, that is my final sanity check.
Thanks,
Chris
pvanv
Yes. Siamese coil. Both plugs fire on both compression and exhaust.
