Car: 1993 Nissan Quest van<br /><br />Problem:<br /><br />1. Tire wear on the inside edges of both front tires. The wear goes in approx. 1" from inside edge.<br /><br />2. The van pulls/drifts to the drivers side.<br /><br />3. The brakes pulsate when you apply them.<br /><br />4. The CV joint boot on the drivers side (at the wheel)is split, and clicks when you turn one way or another. Obviously the joint is bad.<br /><br />One shop said the struts are causing the tire wear. I have never serviced struts, so I am not familiar on how they wear or breakdown. <br />Would struts cause this kind of tire wear?<br />If so, what should I replace? The shocks, springs, everything? What is entailed in a 'strut job' ?<br /><br />The brakes were JUST services a few months ago, so I find it hard to believe they are out-of-round. This is obviously a separate issue that I will be taking up with the shop who did the work.<br /><br />Would a bad CV joint cause any of the above issues?<br />Speaking of a CV joint, I am told to get the bolt-in job, and not bother to rebuild it myself.<br />Has anyone ever tackled this?<br />I think it's called a 'half-shaft' ?<br /><br />The van has been great. IT has approx. 145,000 miles and still runs like a champ. This is the first real problem it's ever had. I'm not surprised it needs a few parts, and I'm willing to fix it.<br /><br />Thanks for your help.
