demarko210
- Jan 2, 2015
- 655
I am trying to find a device that will place my tilt/trim position on my NMEA network. I was wondering has anyone found such a device that will plug into NMEA/Mercury to read tilt/trim angle? I have been looking at Yacht Devices Rudder adapter for their trim tabs this device seems to covert ohm or volt to angle position for trim tabs. I also found this device but according to the one review it does not covert signals to NMEA. I also found this Garmin device if anyone knows about this Garmin and if it works let me know.
My engine gateway for some reason is not reading my trim position on the motor. I removed the analog trim sender and installed the digital trim going to the ECU. I have a Mercury 03 150 sw. My last result will to be just to install the Smart Craft SC1000 gauge. My purpose just trying to find my engine/tilt sweet spot when cruising down the bay. I have fuel flow but I would like to know the exact angle my trim is in when I plan on taking a long cruise I can just lock in it. Thanks.
