Can the engine be started without the outdrive in place? I finally got everthing hooked back up to the engine, cleaning wire contacts as I went. I wanted to turn it over while the outdrive was at the shop, but when I turned the key, nothing happened except that the guages moved. No click from the solenoid. I put the shift lever to the neutral position, but still no click. I don't have a safety kill switch so I know its not that. I am thinking perhaps the neutral position safety lockout switch might be the culprit, but then, I don't know. Where should I start checking? 1971 18'Trisonic, Ford 302, 188hp, Pre-Alpha drive.
