Halstead666
- Jul 23, 2014
- 19
I have a 1996 5.7 alpha mercruiser things were going fine until I decided to make a valve adjustment as I thought I might gain a little more on my top end if done properly........I know now that I should have left it alone but I could not help myself as the top end has only been going to 4000 and should higher as in the 4600's or so.....Anyways I did the valve adjustment as per the mercruiser manual for my engine or at least I thought I did as I marked the valves incorrectly when making each adj on TDC #1 then #6 ie i marked the exhausts as intakes and intakes as exhausts......thus no compression. After rereading the manual I discovered my error and then made the correct adjustments as TDC# Intakes - 1,2,5,7 & Exhausts- 1,3,4,8 then @TDC#6 Intakes -3,4,6,8 & Exhausts- 2,5,6,7 all adjusted one full turn once at zero lash. Figured this would do the trick and get me back to running normal again......put compression test on #1 and got 150 and was happy but then got 0's on the others?.????? I am pulling my hair out on this one and was wondering if you guys have any suggestions for a fix?
Mark Tiernan
Mark Tiernan
