No Compression in bottom Cylinder.
91Force90hp
1991 Force 90hp. I lost compression in the bottom cyl. Whats the least evasive way to re-ring the cylinder?<br />Or should I look for other problem(s) that may casue it?<br />Thanks!
JB
Re: No Compression in bottom Cylinder.
Howdy, Force.<br /><br />Welcome to the board.<br /><br />I think you will do a lot better on the Outboard Engines Forum.<br /><br />Good luck. :)
