No cooling water
sknew
2002 Honda 115 hp 4stroke. I have no cooling water coming out, but do feel air coming out. Does that mean water pump is working and intake clogged? I could not reach the intake from my boat, will have to turn it around on the dock.
pvanv
Re: No cooling water
You are not pumping; that is exhaust backing through the system. Install a water pump kit.
pvanv
If that matches your model, it should be OK. Personally, I try to use Factory kits rather than aftermarket when I can.
smilndawg
I have read that you will need special tools to replace the seals P/N 's 07936-3710600, 07936-3710200,and 07936-3710100. What are they and were do I find them ,if I really need them. I am about to do a compleat rebuild on my honda 115 water pump soon. :lol:
TOHATSU GURU
You don not need any special tools to replace a waterpump repair kit. Stay away from getting into unnecessary seal replacement. IE Do not take a simple thing and turn it into a complicated thing....And Paul is giving you a great tip about staying with original manufacturers parts.
