oldsubsailor
- Sep 1, 2016
- 5
I just purchased this boat and motor and know absolutely nothing about them. I cannot get the motor to start. It ran at an idle hooked to a hose when I was looking at it prior to purchase. Have not been able to get it to start since I brought it home. It was giving me a half start, then the starter would disengage and spin down. Now I don't even get that so I checked the fire with a spark tester, no spark on either the port or starboard bank. Went to the book and it said to check resistance between the leads at the four pin connector that " connects the leads from the power pack to the timer base". This I did, I get good readings on the port bank (12 ohm) and the same readings on the starboard bank on all except 1 pin, D to A reads 34 ohms, the other 3 read as should. The book now tells me that I need to replace the sensor coil. I am not sure this is the problem, mainly because when I pulled the plugs out and did a compression check on all 6 cylinders, I noticed that #2 plug looked as if it had never been fired, looks brand new the other 5 plugs looked used, not bad, just you could tell that they were firing. I talked to the previous owner whom had the boat for about 2 or 3 years and took it out and operated it about 3 years ago then decided to redo the deck and furniture and such. He states that he did not replace the plugs at anytime when he had the boat. I know the boat was running (idle) and that the # 2 cylinder was not firing for some reason or another and that now, I have nothing for fire on anything. Does this sound like a sensor coil and is the sensor coil something that I could replace myself or is it a highly technical procedure requiring special tools and gauges and the like.
