I put a new stator and trigger on it.<br /><br />Found a loose wire on the key switch (orange)<br />and fixed it - gave me 12 volts across the second top terminal (from left) on switch boxes.<br /><br />Fired up and ran 5 minutes and it cut off - now <br />no fire again.<br /><br />Could it be bad key switch? <br /><br />Question? Should you have 12 volts accross the <br />switch box as I indicated above? It seemed to make the difference in making it start before?<br /><br />Could the switch boxes have gone bad? How can I check these?
