Re: no fire on 1979 140 merc
No spark on any of the 6 wires? A 79 uses the ADI system, 2 switchboxes, 6 coils, 1 trigger assembly, and 1 stator. Could be a bad switch in the control box, a pinched or open wire.
The mercury switch, also called a tilt switch, is there to prevent over revving if the prop were to leave the water due to the engine tilting up when striking an underwater object. It also reduces the slamming of the engine against the transom.
