No fuel to the carb
tunaboss
It's an 06 mercruiser 305 with 2bbl carb and electric pump, full tank of fuel.
It runs if I spray starter fluid in the carb, but will not run on it's own. I figured bad fuel pump and removed it hooked it up to the battery charger and it hums, Re-installed it, and hooked it up and it still hums. But not getting any fuel.
Could the fuel/water filter be bad, what should I look at next?
Or, can the fuel pump still be bad, what other test can I do.
Thanks,
Bob
alldodge
First don't do that anymore, your going to damage things, if you have not already don it. The motor will run if you just pour a couple ounces of gas down the carb
Being a 2006, I'm thinking its not a carb but throttle body injection (TBI).
What is the motor serial number?
tunaboss
Thank you, the spray was done before I got to it, However, I replaced the fuel filter separator as it had a hole in it, so I think the pump was sucking air. Anyway, new filter and it's running great.
Thanks again,
